ORIGINAL: tattguy12
46u since you have a savage also i hope you can help me, ive stripped out two stock 52 spur gears...is there somthing i can do as a good fix to this problem?
thanks for your help
Are they striping or melting? The reason I ask is the only spur I had a problem with in over 6 gallons of fuel was when I was breaking it in and it melted do to the sorry stock composite clutch shoes slipping so bad it got the CB so hot it melted spur. I have at least 6 gallons on the spur I am running now. Setting mesh is critical as well.
