RE: Easy Star brushless question
I have an E Star with a geared inrunner brushless motor that weights the same as the Speed 400 stock motor, it is mounted in the same hole, and I have to use the biggest, with the most weight lipo 2200 3 cell, all the way to the nose to get the cg right. You may want to check out the cg before attaching the motor. Good luck
Himeros
