I think the first and third planes listed might be a bit much for you. The 4* is easy to handle but it will float worse than your trainer for landing. You might be able to handle a Chipmunk, or maybe not. Since you are looking at the 60 size kits I think a Tiger would be a better choice for now. It has a good size which makes it easy to see and its a solid build. It has a good speed range, is aerobatic, and it is forgiving when you need it to be.
http://www.greathobbies.com/products...prod_id=GOL068
