RCU Forums - View Single Post - OS Max 46FXi
Thread: OS Max 46FXi
Old 10-23-2006 | 02:24 PM
rlipsett
Default RE: OS Max 46FXi
sounds like your low end mixture screw is improperly adjusted. If you don't get this close to the proper setting the high speed will never work properly over the operational range and you will just be chasing the settings all around 1 click to rich one click too lean. how many turns is the low end out from all the way in?
