RE: Need Help Getting Started
Ok A Tl-01 is a ladder type chassis and is roughly about 10-15 years old and getting hard to find parts for.
A TT-01 is a Tub chassis and is a lot more modern, no it isnt as adjustable as a Yokomo but for the price you pay, you cant expect it to be..
TT-01 is a great Drifter chassis and doesnt need to be adjustable for drifting. The stock camber and toe in is fine.
It just needs an alloy prop shaft and bearing kit..to make it better.
As far as controllers go, A pistol grip is desired.
a Futaba 2pk or 2pl will do fine..
Depending on which TT-01 you get you may need an ESC..
preferrably a no limit ESC with Reverse..
