RCU Forums - View Single Post - Postioning Glow Motor
Old 10-23-2006 | 03:24 PM
opjose's Avatar
opjose
Default RE: Postioning Glow Motor
The motor mount has the correct down thrust and right thrust angles for the PTS P-51.
You really do not want to change the thrust angles unless you have done something like screwing up a motor mount, so that the engine is slightly angled, etc.
Since most mounts are resin-plastic, I normally sand them down using a planar or band sander, to get any changes to the thrust I desire.
This works pretty well as the base of the mount is still entirely in contact with the firewall. It's also very easy and quick to do.
