RE: Top Flite Staggerwing
As I was joining the top wings togther with the metal spar, the intructions tell you to epoxy the spar into the left wing only; but when you look at the picture it shows the metal spar in the right wing. If you go stictly by the pictures, you will have glued the spar into the right wing and not the left. The right wing has a screw that fastens to the spare and therfore no epoxy is needed. This picture is on page 11 of the manual.
John
