RE: Heli engine losing power while hovering
Your engine is to lean and I would reccomend that you fix it quickly. You adjust the needle valve a few clicks at a time while it is on the ground idling. A good idea is to hit thottle hold while on the ground that way if the collective stick gets bumped it doesn't try to spool up.
