RE: Postioning Glow Motor
Nearly all models benefit by having a degree or more of right thrust built in. This is often done when the plane is built as the firewall will have the built in offsets on the better designs. You can experiment a bit by simply putting some washers or spacers between the back of the motor mount and firewall to change the thrust line and find out what works best for your model.
