RCU Forums - View Single Post - Motor Will Not Start
Old 10-24-2006 | 02:44 PM
bruce88123
Default RE: Motor Will Not Start
When I start an engine I will usually do it at "high idle". There should be about 1/8" opening in the throttle barrel. This will allow a little fuel and a liitle air into the engine. If it has been primed properly, it should start.
Definitely check the plug for a glowing element. If not glowing it can be either the plug or the ignitor.
