RCU Forums - View Single Post - Motor Will Not Start
Old 10-24-2006 | 04:31 PM
InIt4MyBoys
Default RE: Motor Will Not Start
stick a finger of the hand you are using to hold the plane over the hole in the end of the muffler as you crank over the prop. this will ensure that the motor is sucking fuel into the engine. I had lots of trouble starting cold engines until i was taught this trick.. do please look first to make sure that you are doing this in a completely safe manner.
