RCU Forums - View Single Post - Engine makes noise after crash
Old 10-25-2006 | 12:04 AM
reyn3545's Avatar
reyn3545
Default RE: Engine makes noise after crash
If you've already run that many tanks through it with noisy bearings, you've likely damaged the crank already also... I'd just run it until it snaps. The money you might save by replacing the crank/bearings now would be likely be spent again soon.... you've had metal shavings cycling through the engine this whole time.
