RCU Forums - View Single Post - Skymaster F-4E phantom
Old 10-25-2006 | 05:03 AM
  #145
MNModels's Avatar
MNModels
Default RE: Skymaster F-4E phantom
Dear Hank,
I would like you to calculate the load on the Comp-arf mig 29! It uses a single 15mm spar for wing. The model weight 50% more than F4 and uses double the turbine power!
I have seen Thomas Singer fly this beast to the limited in Germany! And yet i have to hear of an in flight explosion.
The F4 uses 2 x 14mm carbon rods. Total 28mm. One in front and one at back.
The elevator uses 4 bearing mounts.
Skymaster have tested this model with P-180 power and is satisfied with results. But if you do i vertical dive and pull full up elevator, there will be no gaurantee that it will last! For normal scale and aerobatic flying it should be fine!
Regards
Morne
