RCU Forums - View Single Post - Skymaster F-4E phantom
Old 10-25-2006 | 08:35 AM
  #153
RCUser012
Guest
My Feedback: (73)
Default RE: Skymaster F-4E phantom
hey, you take a risk with everything .. you would think that something like a BVM bandit would be perfectly engineered and tested, and look at what happened to Adil's .. the wings just ripped off because of bad spars ... others have been fluttering apart for years now as well .. and this is a plane that goes through a ton of engineering and testing. ( im just using this as an example of a highly tested quality manufactured airframe representative of the upper standard of RC jet engineering )
Some issues with kits failing out there are with the actual manufacturing .. others ( like flutter) are typically user induced ....
I'll tell you what, the thing that stands out the most about this F4 is not even the detail and outline that is actually more scale than other popular F-4s on the market, but it is how beefy and rugged the constructions is. I can see this plane being flown hard without much of a problem. Though Adil is looking to fly this plane in a "scale" fashion, he is no pansy (at least not in the way he flies .. i can't comment otherwise ) and im sure it will be put through its paces [8D] .. and if the plane is to fail, at least it will be a spectacular crash considering its size
Voy
