RCU Forums - View Single Post - what a difference a prop makes - DA50
Old 10-25-2006 | 04:57 PM
zzw26n's Avatar
zzw26n
My Feedback: (45)
Default RE: what a difference a prop makes - DA50
pe reivers, did you have your Milk money taken from you as a child when you went to school?
Ragz, In my opinion, the Mezjlik 23 X 8 is the best all-around prop for the DA-50. It should put you in the 6800-6900 RPM range, provides good down-line braking and will pull a 16lb Plane vertical very nicely. Sea level, temprature, etc. will all effect the RPM's.
Did you notice the Mezjlik prop to be a little quiter?
regards, zz
