RE: Engine makes noise after crash
RC-Bearings.com is the best place to get your new bearings at a reasonable price .plus your crankshaft should be fine unless it got bent in the crash which is another possibility where your noise it at.Easy to tell if you look at it when running and the end of the crank is not running true or if you have a spinner and it wobbles .
If the engine still has good compression and runs ok ,just makes noise stick some bearings in it and go fly.
