RE: US41 engine
Hey nchrome! Got the crops all in?? Ready to start flyin' again? Just to give you a little encouragment, the 41's will or should work quite well, worst thing that can happen is for one of them to decide it's time to rest at about 200 ft. off the ground. I put a TF 51 together, and put a Fox 3.2 in and at 20 lbs. it is quite impressive and exciting to see fly. It is fast as it should be, and the power is impressive. The Fox is unfortunatley quite pricey, but the Brison I bought this spring was not, that is in a BME Edge and boy what a plane. I had an issue with the ignition, but replaced it with a CH I had on the bench.
Are you done with harvest? Good yields?
Dale
