RCU Forums - View Single Post - how to start
Thread: how to start
Old 10-26-2006 | 07:38 AM
Nitronutt's Avatar
Nitronutt
Default RE: how to start
ORIGINAL: Tim0
What if when you pull it there is no resistance sometimes and other times there is? Is that normal?
There should always be some resistance when the piston gets close to the top of its stroke. As it passes the top of its stroke, you should hear/feel the pop of the compression releasing. If the engine is not currently overheated, is really difficult to tune (and overheats really frequently - but has no air leaks) and you have no resistance (But the piston is going up and down while you pull), it is probably time for a rebuild (new piston and sleeve).
