RCU Forums - View Single Post - Seagull Models Super Star 120 engine/servo selection
Old 10-26-2006 | 10:12 AM
rccardude04
Default RE: Seagull Models Super Star 120 engine/servo selection
I was thinking about either that or just using a slightly larger tank. I've just heard from a lot of people especially locally that the larger 4-strokes work MUCH better with a pump. Saito actually sells one for $29.99 that runs off of the little oil nipple on the backplate (http://www.horizonhobby.com/Products...=SAI300TTDP102). I guess I could try it as-is and if it leans out, I can try the pump. Or, if I don't get enough flight time, I'll probably try a bigger tank (or a second one) that will probably at least be happier with a pump.
http://www2.towerhobbies.com/cgi-bin...&I=LXHKB0&P=ML How's that look for a servo?
Thanks again guys.
-Eric
Edit: I guess I also should ask ... what should my flight times be on the stock tank? It's 20 oz.
