RE: gas fuel with glo plug no ignition
It wouldn't be much different than pouring in the gas "anti-freeze" or "drier"; the products sold to absorb water in gasoline. Those products are mostly methanol, which is what is in the glow fuel. The nitro percentage would be so diluted it shouldn't be a factor. There's no lead in mix so it shouldn't hurt the oxygen sensor or catalytic converter. The 3% oil shouldn't hurt anything either. The one concern is when you guys put it in your other two stroke tools. If you don't richen the mixture up, you could seize the engine.
AV8TOR
