RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 10-26-2006 | 08:00 PM
  #3596
FERNDALE AIR FORCE's Avatar
FERNDALE AIR FORCE
Default RE: Air Hogs Aero Ace!
Hi, Micro does it fly within the general confines as an aa. Is it yard flyer? I'm looking for them either way Maybe hobbytron or hobby people.
I have a theory on why the aa burns transistors. As far as my planes are concerned all of the 06's get interferance from the bottom wing. Mega-byte mentioned a while back that interference with the prop can cause a surge in the transistor. As I understand it, the transistor is allowing max flow, but the prop is unable to spin at max, and the electrons "back up" in the transistor because they can't flow. This would cause heat, from resistance, and burn the transistor up.
If this theory is correct, there would be few options to solve the problem. Cut the lower wing where the prop hits, remove the lower wing entirely soon after purchase, and replace the transtors. Does this sound rational, or am I just overthinking? Has anyone burnt a rx on the jet?
Tim
