RCU Forums - View Single Post - need an electrical wizard for this one... BCX 4N1 has problem
Old 10-26-2006 | 08:54 PM
john68
Default need an electrical wizard for this one... BCX 4N1 has problem
Ok, so here's how it started...
The JST connector got stretched and finally the neg lead broke off, so I took the old connector off, and not having a replacement, direct wired the leads to the battery pack. not a problem, except for a split second, I had them reversed, and smoked the MOSFET controller. Not a problem... I went to www.digikey.com bought 3 mosfet controllers and replaced it, the other 2 chips I got to repair another fried 4N1 on another BCX, and the other chip as a spare. So, I replaced the MOSFET on the one BCX, and everything works fine.
Now, the one BCX 4N1 that I reversed the leads on...
I replaced the MOSFET that got smoked, and the motors work fine. While I was in there, I put a brand new longer plug for the battery in, soldered tot he board. Took teh old one out, soldered in a new one from hobbico. Motors work fine, but when I plug in the servos the green LED dims, and if I move the cyclic controls, the LED dims more, nothing happens with the servos, and it slows the motors down.
Why? What else coudl I have fried in there, that would cause this.
I want to add, that when in there, I noted that some of the components differed from the first 4N1 that I worked on. some of the components are in different locations, and the antenna is routed differently through the board.
I didn't see any other components that were visably toasty or discolored.
Anyone hazzard a guess as to the problem?
John
