RCU Forums - View Single Post - os 160 fuel problem
Old 10-27-2006 | 11:08 AM
Bax
Default RE: os 160 fuel problem
ORIGINAL: typhoonfury
bax, where and what size larger fuel tubing, do you need for the BGX-1 3500?
ALSO can you get a larger fuel nipple?
thanks
We use the brass tubing that has an I.D. that's the same as the O.D. of the tubing supplied with the tank. We drill the clunk so that it has a constant I.D. The I.D. of the fuel end is smaller than the I.D. of the end where you attach the fuel tubing.
