RCU Forums - View Single Post - ch ign for g20...?
Old 10-27-2006 | 11:27 AM
ddotson
Default RE: ch ign for g20...?
Mine will tick over all day at about 2000 and go to full power without hesitation. The carb settings are pretty much factory. Beginning to trust this little engine a lot. My first venture into gas. It is on a Funtana 90 and getting stronger every flight. Mine has very low vibration, a lot less than the Saito that was on the plane, VERY pleased. I don't like the way it eats batteries, but I charge about every two flights just for peace of mind. There is another thread where a firm in England sells a small, light lipo for this engine. They claim it will run engine 70 minutes. I think if a g20 wont run pretty well at factory settings on the carb there is a problem that twisting needles is not going to fix. BTW mine idles so low that it will BARELY pull the Funtana fuse on pavement. I thought about the lipo thing, but just leary of gasoline, lipo and cigarettes.
http://www.toni-clark.com/index_en.htm
ORIGINAL: tkg
Mine would idle all day under 2300 rpm, untill you gave it a hard flight. Then it became not so good. I've only got about 30 flights on it and want to get some more time on it before I say its bad.
New engine, new tuning job, different airplane all need to be sorted out first.
