RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 10-27-2006 | 01:03 PM
  #5549
rclement's Avatar
rclement
Default RE: U-Can-Do 3d 46?
Choopi, Glad you're here. The 82 and 14x4 are perfect for it. As far as the LG collapsing are you saying the block has come out? If so that's a common problem with them but very easy to fix. A good fix for it is to take the LG off and drill a couple of holes for some metal pins that will go from the surface that the LG goes on down through at an angle and come out of the plywood section that is where the belly pan butts up against. It basically pins the LG block to the plywood bulkhead behind it. Let us know how you come out with it.
