Ya, its called the Instruction manual for the Sig LT40. You get it with the kit. The instructions are numbered and so are the parts. Then it shows you pictures of the actual part to save you time looking for it as you piece together and then glue the parts together. Check off the numbered instructions as you go along and when you quit building for the day or evening, then you know where you left off. The parts are cut out and notched to fit correctly so as long as you are paying half attention during the build, you really can't go wrong. You learn more by doing than just reading and an LT40 kit is a great way to start! Perfect time to buy it now by Spring the plane will be finished and ready to fly.
