RCU Forums - View Single Post - Centering the Carb Butterfly?
Old 10-28-2006 | 09:47 AM
davewallace
My Feedback: (29)
Default RE: Centering the Carb Butterfly?
MrBigg,
That is a very interesting finding. If you think about it, the butterfly should be aligned with the center of the flow into the port. The port opening is progressive, with the bottom opening first and staying open for the intake duration. As you go up the port is open for a progressively shorter time. Since the flow would not be evenly distributed accross the port, why should the butterfly be centered for peak RPM?
Dave
