one more suggestion... i've had this 'once touch stick then drop' sydrom. DO NOT TIGHTEN THE SCREWS ON THE MIXER ARM TOO TIGHT. make sure that it'll move freely. and try adding a shim or two between teh orings and the bearing shim. if you get a somewhat nodding effect afterward... remove a shim... hope this helps.
