RCU Forums - View Single Post - Centering the Carb Butterfly?
Old 10-28-2006 | 10:19 AM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Default RE: Centering the Carb Butterfly?
It's a not a bad idea to give this butterfly position a quick check when setting things up.
I too have experienced it with one engine and in my case, it actually ran faster with the butterfly slightly closed from a centered position...
And no, it wasn't a mixture problem as I checked that possibility first! I just couldn't believe what I was seeing and thought it had to be a situation of the HS needle being too lean, but that was not the case.
