RCU Forums - View Single Post - 7CAP elevator channel problem
Old 10-28-2006 | 10:26 AM
garyandnancy
My Feedback: (46)
Default 7CAP elevator channel problem
Hi,
I recently acquired a 7CAP and am experiencing a problem that I do not understand. With the elevator (channel 2) and only the elevator, when the ratio is at neutral, the servo is positioned at almost full travel to one direction. When I revers the servo, it travels almost all the full possible travel in the opposite direction. My trim and sub trims are at 0, high and low travel are at 100%, and no mixes are enabled. I tried using the master reset on the radio, that made no difference, and the modulation is correct. When I move the servo to another channel, rudder for example, I do not experience this problem. I have tried different servos and different receivers, but the symptoms do not change. Thanks in advance!!!
