RCU Forums - View Single Post - What does washout means?
Old 10-28-2006 | 03:28 PM
da Rock
Default RE: What does washout means?
but I have not clear what exactly means and how affects on my planes
It's effect is to reduce the total lift generated by the wing at all speeds. It might also reduce the possibility of the airplane rolling when the wing or any part of it stalls, since the stall may occur more often toward the center as opposed to the tips.
Since a wing without LE or TE taper has no tendency to stall first at the tips, it's usually a waste of time to physically twist them.
