RCU Forums - View Single Post - New G3.5 Upgrade
Old 10-28-2006 | 05:45 PM
  #66
heli_Rod's Avatar
heli_Rod
Default RE: New G3.5 Upgrade
RealFlight G3.5 BETA is available for download. I just got it installed...pretty cool stuff.
FOLLOW THE INSTRUCTIONS CLOSELY!
G3.5 Public Beta available
RealFlight G3.5 is now available as a public beta download! Version 3.50.033 will be made public soon, but here is your chance to get it early.
Perform the following steps to obtain the update:
Start the RealFlight G3 Launcher
Click Additional Options, then Technical Support
Click Enter Tech Support Code
Enter the following code: B#x7a4ea45jhhc (If successful, you will see a message saying "You are now registered to use the Public Beta site until the new version is posted to official download site.")
Go back to the main Launcher menu and click Registration/Updates
Make sure that in the bottom left corner it says Temporary Public Beta (PS). If not, try reentering the code
Click Update to Specific Version, choose 3.50.033 from the list, and click OK.
The Launcher will need to restart partway through this process. Answer "Yes" when it asks if you want to continue downloading the new version. When this process is finished, you will have RealFlight G3.5.
NEW FEATURES:
Night Flying - Many aircraft now support glow effects at night.
Dynamic Sun Angle - You are now able to change the sun angle at 3D airports (not supported in PhotoFields).
New Airports - G3.5 includes several new PhotoField airports, including Waco Field, home of the XFC.
New Grass Objects - On certain PhotoFields we have placed grass clumps that add an additional level of realism as the aircraft wheels roll across the terrain.
New Aircraft - The Heli-Max Axe EZ and Heli-Max Axe CP have been added, as well as the ElectriStar, FlyZone Cessna, and SkyFly models.
Variable Pitch Propellers - The "V-Pitch" system is now in the list of available propellers
Coaxial Helis - Coaxial helis, like the Axe EZ, are now supported
Streamers - You can now add streamers to any aircraft. You choose the color, width, and length of the streamer.
Responsive Objects - Many objects now respond to collisions. So if you fly into a ladder at the Air Race airport, the ladder will fall over. Barrels at the "Carnival" airport can be knocked over and pushed around by aircraft as well.
Multiplayer Collisions - You can now crash into other players when playing online.
New particle effects - Crash into the ground at Joe's Garage and see the dust spring from the ground. Hit a tree and leaves come out the other side. The Castle airport now has a fountain. When an aircraft breaks apart, pieces come out of the broken areas.
New Beginner Heli VFIs - Brian Bremer teaches the basics.
New Trainers - RealFlight G3.5 adds new "trainer" features. There is a Heli Hover Trainer, Airplane Hover Trainer, and a Heli Orientation Trainer. These trainers are like mini-games that encourage you to practice your R/C skills. The Heli Orientation Trainer is very challenging and requires that you pass each level to unlock a new level.
New Aircraft Editor Features - The menus have been reorganized and some helpful new features have been added. You may now select a component by clicking it in the wireframe display. You may now set the camera to Top, Side, or Front views with a button press. New hotkeys have been added as well. A new "Wave Generator" electronics component has been added, which can be used to flap a wing, rotate a beacon, twirl a streamer, or otherwise act as a servo would except that its input is time-based.
Animated Airport Objects - Many objects, such as the ferris wheel and the roller coaster at the Carnival airport, are now animated.
New Emitter Objects - You can now choose to add Sound, Fountain, and Smoke emitters to airports. We've added exhaust smoke to the truck at RealFlight Ranch and "moo" sounds to the cows at Green Valley.
