RE: Carl Goldberg Ultimate 10-300 Build
You might want to consider dual servos for ailerons in lower wing. You will have to build some servo mounts in the wing and use a y-harness. It will be alot more responsive on aileron control than the single set-up with the bellcrank. I used digital servos because that is what I had around but I run a 6 volt flight pack to increase the torque.
