RCU Forums - View Single Post - TC-3 or TT-01????
Old 10-29-2006 | 12:36 AM
xeliman
Default RE: TC-3 or TT-01????
no problem pal,i can tell you anything you want,what is your setup to the tt-01? i suggest put a lithium grease every time you rebuild it its very effective,if you buy a mod motor,you need to rebuild it every 2,4 runs so it works smooth,a very low cost good motor is the Peak Performance raven s motor,but for speed the lrp 9t will do the job.i forget i have also a f201,a f103gt,a tlt-1,a tc4,a hornet,and a marui vintage jeep.,2 airtronics radios (xl2p,cs2p) the only problem with the ta-04r for me is that it has too many parts i need many hours to complete it the ta-04r has one of the best tamiya tires,frond a rear ball differentials,stabilizer f&r,ball bearings,turnbuckles,aluminium shocks that are adjustable,carbon upper deck,and many metal parts,i think this car is really a pain in the ass coz you can adjust almost everything on it,even the smallest part,the only hop up i think it need`s is the aluminium wheel hub
