RE: WACO YMF
If you are not happy with the amount of toe-in on the mains, now is the time to mend the situation. You will probably have to re-solder the joint if you add heat to bend the gear. They need about 1 degree of toe-in to track straight.
Bill, AMA 4720
WACO Brotherhood #1
