110 Osilation Problem
too much weight,,, once you remove the engine and tank and replace it with motor and battery the weight should be close,,,certainly not a whole extra pound
engine weighs more than motor
Battery pak weighs more than tank so it evens out
plus you can remove the servo battery so It may weigh even less than with the glow engine
