RE: WACO YMF
Bill,
I guess it is like reworking an old house, first you have to tear the place up, then you fix it correctly. I don't see a datum line on the plans what / where do I measure against? I had placed a short level on the motor mount, blocked the fuse to bring that motor mount level, then used another level to check the stab. That was where I discovered that the stab appeared to have 0 degree incidence. Is using the motor mount the correct way to establish my base line or is there a better way? Also guess I need to pick up an incidence meter to make sure I am right on.
Jim
