RCU Forums - View Single Post - Gator wing adjusters question
Old 10-29-2006 | 02:32 PM
shesha
Default RE: Gator wing adjusters question
Scott thanks for the prompt update, you mentioned that the adjuster will be installed in the back side, I was looking over some arf that came with their own wing adjusters pattern type arf. like world models Groovy, I noticed on the groovy the adjuster is installed in the front and back end, going over the details that came with the gator wing adjusters there is a mention of having the install in the leading and trailing edge of the wing, any particular reason as to why you opted to go with a trainling edge installl.
My specific application will be a for a Biplane, is there a specific need to having 2 wing adjusters per wing rin trailing and leading edge ?
If you have any other pics of completed installs that would also help.
Thanks.
