RE: E-FLITE BLADE CP PRO
Night prowler,
Maintenance: Yes, make sure that all the screws are tight, except the blades of course. Make sure the 2 screws that hold the tail motor in place are tight. The paddle blades tight, fly bar weight, servo arms, main shaft collar. One thing a lot of the guys forget is the spindle, that's the thingie that holds the blade grips to the center hub. Just remove both main blades and take two allen wrenches and check for tightness. I just went through my heli two nights ago, and the screws for the spindle were 2 full turns loose.
Dave / Choppersrule
