RE: painting over a covering
you can also use fine steel wool st scuff the surface as long as there is a dull surface for the paint to grab onto you will be fine.
there several clear coats to use lustre coat from top flight is made to stick to covering, but even water based polyurathane will work as long as the surface has been dulled
