ORIGINAL: choppersrule
Night prowler,
The V2 or V3 skids are easy to attach. Take off the canopy, remove the existing skids. The super skids comes with everything you need to install on the heli, even a new battery tray. The super-skids actuall screw into the already existing holes the the stock skids push into. That simple. As far as weight, they do weigh a bit more, but doesn't effect flight, actually, with the little bit of extra weight, the CP seems to be a bit more stable. Also, it doesn't seem to effect flight time. However, I never let my batteries run that low anyway.
Dave / Choppersrule
Thanks for the info, now where can you buy these at? Thanks
