RCU Forums - View Single Post - E-FLITE BLADE CP PRO
Old 10-29-2006 | 06:40 PM
  #165
choppersrule
Default RE: E-FLITE BLADE CP PRO
ORIGINAL: Night_prowler26
ORIGINAL: choppersrule
Night prowler,
Maintenance: Yes, make sure that all the screws are tight, except the blades of course. Make sure the 2 screws that hold the tail motor in place are tight. The paddle blades tight, fly bar weight, servo arms, main shaft collar. One thing a lot of the guys forget is the spindle, that's the thingie that holds the blade grips to the center hub. Just remove both main blades and take two allen wrenches and check for tightness. I just went through my heli two nights ago, and the screws for the spindle were 2 full turns loose.
Dave / Choppersrule
Yeah iknow about the motor screws and all, So should the screw in the very top of the rotor be tight? tight as it will go? cause that one and the 2 tiny ones on the side under that were little loose so i tightend them also.
so you have to take both blades completly off to check them others right! I had seen them and thought that was the only way to get to them.
You're on the right track. Tighten 'em all. And the spindle shaft, yep, take off both main blades and make sure they are tight too.
If they get to loose, it will cause a ton of vibration. If they loosen all the way, the blades could actually fly off. Don't want that to happen. It's a maintenance thing, it only takes a few minutes to check everthing, a few more for the spindle shaft.
Pays off in the long run. I check mine after every few flights.
Dave / Choppersrule
