Que on wind and elec. connections
Lone Al,
Here goes,
1. After you have a few hours of solo flying, you can fly in as much wind as you are comfortable with, and for now yes, 10 and steady is better than gust.
2.No plug them in , and check them at the beginning of each day of flying. Also, aileron extentions, and other plugs (battery ect.) can be taped with a little piece of scotch tape.
3. A "pinch fit" is no good. Get another spinner or get a Harry Higley Hub, or a spinner/propnut from DuBro. You can also go "spinnerless". The 11X5 will give better climb, and you won't miss the little bit of speed you will sacrafice.
4. If you are learning to fly by yourself, you'll get a lot of people telling you it's not a good idea, or can't be done safely. It can, I did it that way. The only thing to keep you from "just doing it" is the spectre of all your money (plane) turning back into a kit!
TAKE YOUR TIME!! Take it up with a full tank, and make several approaches to land. When you are lined up, and have plenty of space to stop, slowly bring the throttle back and resist the temptation to "hold it off" or, keep it in the air. KEEP PRACTICING ON THE SIM, and when your ready, you'll know. Good luck and keep asking questions. No one will get PO'ed.
Jetts
