Hi merchjo, Some time's the kill switch will stick. Just pull the plug & hold it close to the head & see if U got spark, if so then the switch is OK. You might want to pull the 4 screws off the top of the Carb. & check the rubber under the bulb & plastic plate. Good Luck,
