RCU Forums - View Single Post - Help with electric motor!!
Old 10-30-2006 | 09:26 AM
v_tolias
Default Help with electric motor!!
I've built foame3d from 3dbatix.com.
Because it is just a little heavier ,i though to put a bigger motor!
For good performance(not maximum) the plan suggest GWS EPS-350C-DS/BB (Gear 6,60:1 63g) with GWS 12x6 Slow Flyer prop..
I Though to use GWS EPS-400C-IS/BB (Gear 6,3:1 95g)!!Is it better or not?What prop should i use?
If you suggest an other motor and prop for the best 3D flight i would like to know it...Don't forget that it is heavy..Almost 360 g without motor and prop!!!
Thanks..
