RE: Skymaster F-4E phantom
heres the problem i have found with matching 8611 servos ... if you get them centered to eachother, the end points will slightly be off .. if you adjust this with a match box, and now you have the center and enpoints to match, i have found that the travel "curves" might still varry through the transitions between center and the end poinits ... and on top of that i have also found that speeds might slightly vary also between the 2 servos ... great servo for a single surface, but not for ganging up ..
Voy
