RE: Blade CX Question
Their should be a hole in the outer shaft. I believe that the top hole of the lower head should line up with this hole. Then you adjust the control rods to make the swash level. Little trick unplug the main motors and center your trims power the heli up so the servos are in their neutral position then adjust control rods to make swash level, unplug heli reconnect motors and go fly.
