RE: os 46 engine problems
I had the same problem with a OS 46 La blue and i changed the head the problem stoped but what engine do you have how did you check to find the leak i used light oil and sprayed around the glow plug and on the head bolts and found nothing.a friend told me to remove the engine and dip the top end of the motor in light oil and turn over the engine and poof leak! the head was warped hope that help.
