RCU Forums - View Single Post - Blade CX Question
Old 10-30-2006 | 11:53 AM
CCbusa05
Default RE: Blade CX Question
Yes indeed THERE ARE holes in the outer shaft for the TOP two screws! The bottom two just need to be tightened against the shaft a bit. Needless to say, this will auto align the rotor head on the shaft where it belongs. When you have everything all assembled back together, simply press the two halves of the swash plate together, it should 'snap' back into place for you.
