ORIGINAL: wlcornelius
What is the right way of connecting 2- 12volt batterys together to make a 24 volt system, is it neg to pos, an can it be charged with a 12 volt charger while still being connected as a 24 volt system because it will be a sealed system
Your circuit diagram is correct. To charge the batteries with a 12v charger you will have to disconnect them from one another and chare individually.
What are you trying to turn over that you would need a 24v starter for?
